Sugarfoot Posted February 5, 2013 Share Posted February 5, 2013 I seem to have a problem with the throw out bearing staying attached to the pin on the BA 10. Also noticed that I think it is the same as the ax15? Just a hollow appearing half inch small pin on a round raised area on the front face of the trans. Buying O'reily parts and this is a new clutch kit. The slave has a strap that attaches to it. The strap keeps coming off the pin some how. Is there a remedy or a southern ingenuity fix for this? I consider putting a small screw into the top of the pin but if you break that pin off or split it out your going to be in a hell of a mess. Quick answers are appreciated as I am paying for the lift by the hour. (19.95) We pulled it off the lift and rolled it out of the bay but we need to get back to it tomorrow. James and Sugarfoot, Denton TX Red 1988 MJ Pioneer 4.0 BA10 4x4 D30 and 35 stock 268,000 miles Link to comment Share on other sites More sharing options...
1987Comanche Posted February 5, 2013 Share Posted February 5, 2013 Can you knurl the inside of the strap or perhaps liberally coat it with Loctite or JB weld? All you need is a tighter fit... Link to comment Share on other sites More sharing options...
Sugarfoot Posted February 5, 2013 Author Share Posted February 5, 2013 JB Weld was one of my thoughts it's better than duck tape, LOL . But was looking for more ideas. I have not done this work as I have a mechanic that is doing it. I am extremely busy at work and overtime is aplenty with this project, but I need my truck. It was cheaper to hire this guy as he did have some good experience but I just wonder if he did something wrong or just flat screwed up. But it looks like I'm going to have to do this myself. So to keep from loosing more time at the problem, I want to know my best plan when I get into it myself. any others ideas? Link to comment Share on other sites More sharing options...
1987Comanche Posted February 6, 2013 Share Posted February 6, 2013 What about a different brand clutch? Does the NAPA (LUK) brand have the same fitment problem? I've had fitment problems with ball joints before...switch to a different mfg and the issue goes away. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted February 6, 2013 Share Posted February 6, 2013 southern ingenuity ?? There should be a retaing nut on the pin.It's not clear in the FSM whether it's a threaded nut on a threaded shaft or a push on "nut", like a circular snap ring type thing. All I know is that when I pulled my BA/10 out that the whole assembly just fell out. Link to comment Share on other sites More sharing options...
Sugarfoot Posted February 6, 2013 Author Share Posted February 6, 2013 I think it's just a push on snap ring. This is a clutch kit from O'Reilly's 159.00 all inclusive. Brand says Brute Power. Link to comment Share on other sites More sharing options...
fiatslug87 Posted February 6, 2013 Share Posted February 6, 2013 Luk clutch comes with this. Is the pin falling out or the push nut? I remember some member tapped the hole and used a machine screw. Link to comment Share on other sites More sharing options...
Sugarfoot Posted February 6, 2013 Author Share Posted February 6, 2013 That's what I was hoping some one would show me a pic of. You think lock tight would set that up better? Link to comment Share on other sites More sharing options...
