Cargo Light & Cigarette Lighter Assemblies
MJRemi
Cargo Light: Includes the exterior cab light and the dash panel assembly. I cut the harness wires a few inches from the connectors so the back side plugs are intact. The two screws for the light mount had to be drilled out and the left side put up a fight. The light housing has a hairline crack next to the screw mount but I sealed it up with JB Weld and gave the housing a coat of Krylon. $25 shipped.
Cigarette Lighter: Wires cut in similar fashion. $15 shipped.
Shipped prices are for lower 48, other regions may be extra.
I presume the ciggy lighter worked? Mine is sketchy.
It's from a parts truck which I never operated. I looked the lighter over and it seems to be in pretty good condition concerning corrosion. This is a So. Cal. truck and has very little evidence of rust and corrosion. With that said, I cannot guarantee the lighter works but it is probable.
I just tested the lighter with the truck's battery and it works fine. It took about 8 seconds to pop out hot. The little light bulb behind the symbol is burned out but it's very easy to remove and install a new one if you need it.
Archived
