Comanchemodder Posted January 10, 2013 Share Posted January 10, 2013 I'm going to change my turn signal switch in hopes to cure several issues. Are there any guides out there? Do you remove the steering wheel or do it under the dash? Link to comment Share on other sites More sharing options...
shelbyluvv Posted January 10, 2013 Share Posted January 10, 2013 It is under the steering wheel. Read this write up. http://comancheclub.com/topic/18991-ignition-lock-removal/page__fromsearch__1 Link to comment Share on other sites More sharing options...
Biotex Posted January 10, 2013 Share Posted January 10, 2013 I just did mine to cure some wierd signal/light issues. Turned out someone had swapped in an 1156 bulb into an 1157 socket and shorted the two terminals together. Might check your situation and see if that is the problem also. Link to comment Share on other sites More sharing options...
oldseddie Posted January 15, 2013 Share Posted January 15, 2013 I don't suppose the turn signal indicators glowing with parking lights were one of the symptoms? Link to comment Share on other sites More sharing options...
Comanchemodder Posted January 15, 2013 Author Share Posted January 15, 2013 I don't suppose the turn signal indicators glowing with parking lights were one of the symptoms? I'm not sure. My symptoms included brake lights not working and dash turn signal (green arrows) both light up when the running lights on. I am on the downward slope for the swap. I will post my results. Link to comment Share on other sites More sharing options...
