jahiatt Posted December 29, 2012 Share Posted December 29, 2012 Leaks at the bolt head beneath the fuse box. Identical bolt on passengers side. can't see them on firewall side. Help me out!! Link to comment Share on other sites More sharing options...
Pete M Posted December 31, 2012 Share Posted December 31, 2012 what was in that square hole? Link to comment Share on other sites More sharing options...
jahiatt Posted December 31, 2012 Author Share Posted December 31, 2012 fuse block.........the pic needs rotating clockwise :doh: Link to comment Share on other sites More sharing options...
Pete M Posted January 2, 2013 Share Posted January 2, 2013 I am equally baffled. :dunno: Link to comment Share on other sites More sharing options...
jahiatt Posted January 2, 2013 Author Share Posted January 2, 2013 I rotated the pic and circles the bolt or plastic plug. It have a rubber gasket gasket and it leaks a drop or two. Another just like it under the dash and blower , It leaks a little also. Someone know where they can be seen on the firewall side? Down in the cowl? Link to comment Share on other sites More sharing options...
Pete M Posted January 2, 2013 Share Posted January 2, 2013 if you click the little greenish square above the text box that says "image", you can then paste the address of the picture in the pop up window and the image will appear. :thumbsup: Link to comment Share on other sites More sharing options...
Pete M Posted January 12, 2013 Share Posted January 12, 2013 I still can't figure this one out... :( Link to comment Share on other sites More sharing options...
Biotex Posted January 12, 2013 Share Posted January 12, 2013 Can't you stick your finger into the square cutout where the fuse box was and reach the circled area with a dab of RTV on the back side? It will at least let you know what to look for by feeling if it is flush and perhaps covered in undercoating. Link to comment Share on other sites More sharing options...
Keyav8r Posted January 15, 2013 Share Posted January 15, 2013 After you clean all that rust off you can either POR it or put a coat of Rustoleum primer on it and then coat it with body sealer. Either method should cure the leak. Most forum members will probably recommend the POR method. Link to comment Share on other sites More sharing options...
jahiatt Posted January 15, 2013 Author Share Posted January 15, 2013 Going to POR after I finish replacing the floor pan. Almost there. Link to comment Share on other sites More sharing options...
