ParadiseMJ Posted December 28, 2012 Share Posted December 28, 2012 When I'm climbing a hill, or want to pass someone, and I floor it...it won't kick down. I have the TV cable adjusted properly. Everything else shifts & works fine...except for this issue. Any ideas?? Link to comment Share on other sites More sharing options...
Geonovast Posted December 28, 2012 Share Posted December 28, 2012 TPS out of whack? Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 28, 2012 Share Posted December 28, 2012 :agree: The TV cable is responsible for telling the AW4 when to downshift in relation to the TPS. If you're sure the TV cable adjustment is correct, checking the TPS voltages is the next step. A bad MAP sensor can also cause similar symptoms, so check the vacuum connection and in/out voltages. These procedures are all HERE. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 28, 2012 Share Posted December 28, 2012 Test the TPS on the "trans" side using this: RENIX TPS ADJUSTMENT Before attempting to adjust your TPS be sure the throttle body has been recently cleaned. It's especially important that the edges of the throttle butterfly are free of any carbon build-up. IMPORTANT NOTE: With the Key OFF, and using the positive (red) lead of your ohmmeter, probe the B terminal of the flat 3 wire connector of the TPS. The letters are embossed on the connector itself. Touch the black lead of your meter to the negative battery post. Wiggle the wiring harness where it parallels the valve cover and also over near the MAP sensor on the firewall. If you see more than 1 ohm of resistance, or fluctuation in your ohms reading, some modifications to the sensor ground harness will be necessary. The harness repair must be performed before proceeding. I can provide an instruction sheet for that if needed. MANUAL TRANSMISSION: RENIX manual transmission equipped XJs have only a flat three-wire TPS mounted on the throttle body and it provides data input to the ECU. It has three wires in the connector and they're clearly embossed with the letters A, B, and C. Wire "A" is positive. Wire "B" is ground. Key ON, measure voltage from "A" positive to "B" ground by back-probing the connectors. Note the voltage reading--this is your REFERENCE voltage. Key ON, back-probe the connector at wires "B" and "C". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be seventeen percent of your REFERENCE voltage. For example: 4.82 volts X .17=.82 volts. Loosen both T-20 Torx screws attaching the TPS to the throttle body and rotate the TPS until you have achieved your desired output voltage. Tighten the screws carefully while watching to see that your output voltage remains where it is supposed to be. If you can't achieve the correct output voltage, replace the TPS and start over. Sometimes, after adjusting your TPS the way outlined above, you may experience a high idle upon starting. If that happens, shut the engine off and reconnect your probes to B and C. Start the engine and while watching your meter, turn the TPS clockwise until the idle drops to normal and then rotate it back counterclockwise to your desired output voltage. AUTOMATIC TRANSMISSION: RENIX automatic transmission equipped XJs have a TPS with two connectors. There is a flat three-wire connector, same as the manual transmission vehicles have, and it is tested the same as the manual transmission equipped vehicles, as outlined above—FOR ALL ENGINE MANAGEMENT RELATED ISSUES. However, the automatic TPS also has a square four-wire connector, clearly embossed with the letters A,B,C, and D. It only uses three wires and provides information to the Transmission Control Module. THIS SQUARE FOUR WIRE CONNECTOR IS USED FOR TRANSMISSION/SHIFTING RELATED ISSUES ONLY. Key ON, measure voltage between "A" positive and "D" ground. Note the voltage. This is your REFERENCE voltage. Back-probe the connector at wires "B" and "D". Measure the voltage. This is your OUTPUT voltage. Your OUTPUT voltage needs to be eighty-three percent of your REFERENCE voltage. For example 4.8 volts X .83=3.98 volts. Adjust the TPS until you have achieved this percentage. If you can't, replace the TPS and start over. So, if you have an automatic equipped XJ your TPS has two sides--one side feeds the ECU, and the other side feeds the TCU. FOR AUTOMATIC TRANSMISSION RELATED ISSUES: Check the square four-wire connector side of the TPS. If you have ENGINE ISSUES check the flat three-wire connector side of the TPS. For those with a MANUAL TRANSMISSION--the TPS for the manual transmission XJs is stupid expensive. You can substitute the automatic transmission TPS which is reasonably priced. Revised 09-22-2012 Link to comment Share on other sites More sharing options...
ParadiseMJ Posted December 28, 2012 Author Share Posted December 28, 2012 Thank you...if it stops raining I'll whip out the DMM and go to town, but like I said this is truly the ONLY problem I've had since I swapped in the AW4. I thought it may have something to do with the wimpy 3.07 gears. Going up even a shallow grade is brutally sluggish as soon as the RPM's drop below 2K, I feel like I'm driving a 1964 VW bus, towing a 40' trailer, dragging a dead body, with the pedal to the metal. On the freeway and on little hills it's fine, no dead body. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 28, 2012 Share Posted December 28, 2012 Torque converter unlocking? Link to comment Share on other sites More sharing options...
Geonovast Posted December 29, 2012 Share Posted December 29, 2012 Those 3.07s certainly aren't helping your power issues, but if everything was working correctly, it should be downshifting a lot sooner with those things. I would get at least 3.55s in there as soon as possible. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 29, 2012 Share Posted December 29, 2012 Cruiser’s Trans Plug Refreshing Over near the transmission dipstick tube are 2 rather large connectors. One is black and the other gray. These 2 connectors carry all the info between TPS, TCU, NSS, speed sensor, and transmission solenoids. Unplug each one, visually inspect for corrosion or bent pins, spray them out with electrical contact cleaner and plug them back in. Additionally, if your Jeep is an 87 to 90 Renix, it’s always a good idea to reach up under the glovebox area and unplug the connector to the TCU and spray it out along with the receptacle of the TCU. While you’re there, find the fuse right in that area for the TCU. Remove it and spray out it’s receptacle and clean any corrosion from the fuse. Revised 9-10-2012 Don't forget to do this while you're poking your noggin under the hood: Link to comment Share on other sites More sharing options...
