relyt120 Posted December 10, 2012 Share Posted December 10, 2012 Hey guys, today I picked up a blue chime module and an xj visor at the jy. I was under the impression that the blue chime module would chime if you left your lights on, so far I am unable to produce this result; I really need it I have been known to leave my lights on from time to time. Can someone set me straight regarding the chimer? Regarding the visor I know some people have modified the xj visor to fit the mj, how much work is it? I am not afraid to put a little elbow grease into it, this was the first one I have ever seen irl so I had to have it. For $9 you can't go wrong :thumbsup: Link to comment Share on other sites More sharing options...
Harley Posted December 10, 2012 Share Posted December 10, 2012 Ive got a visor on mine specifically for the MJ, from what I understand the distance between the rain gutter and top of the roof line is higher??? on the XJs. or maybe its the other way around. Either way I doubt it would look that great seeing as how it wouldnt line up properly and would probably risk cracking the visor if ya force it too much. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted December 10, 2012 Share Posted December 10, 2012 Might be interested in buying it (visor) if it won't work for you. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 10, 2012 Share Posted December 10, 2012 Regarding your chime module. Use the below to determine if you are getting the 12V signal on module pin 8 when you leave the headlights on and remove the ignition key:[tab][4] [3] [2] [1][8] [7] [6] [5]The tab is the lock tab that holds the buzzer in. Pin 5 is a blank.Pin 1 is powerPin 2 goes to the instrument clusterPin 3 is groundPin 4 is the seat belt inputPin 5 blankPin 6 is the door switch inputPin 7 is the key in inputPin 8 is the headlight input Link to comment Share on other sites More sharing options...
relyt120 Posted December 10, 2012 Author Share Posted December 10, 2012 Awesome, thanks hornbrod :bowdown: Link to comment Share on other sites More sharing options...
