banshee Posted November 23, 2012 Share Posted November 23, 2012 guys got myself an 87 manche rinex 4.0L after it was mudding ran fine, now nothing no fire any ideas where to start??? B... Link to comment Share on other sites More sharing options...
ftpiercecracker1 Posted November 23, 2012 Share Posted November 23, 2012 take cap of Dizzy, dry up mud/water. try to start if nothing, Coil or ignition module (coil $35) (module $135) Link to comment Share on other sites More sharing options...
cruiser54 Posted November 24, 2012 Share Posted November 24, 2012 Check your CPS output. Renix CPS Testing and Adjusting Renix CPSs have to put out a strong enough signal to the ECU so that it will provide spark. Most tests for the CPS suggest checking it for an ohms value. This is unreliable and can cause some wasted time and aggravation in your diagnosis of a no-start issue as the CPS will test good when in fact it is bad. The problem with the ohms test is you can have the correct amount of resistance through the CPS but it isn’t generating enough voltage to trigger the ECU to provide spark. Unplug the harness connector from the CPS. Using your voltmeter set on AC volts and probing both wires in the connector going to the CPS, crank the engine over. It won’t start with the CPS disconnected. You should get a reading of .5 AC volts. If you are down in the .35 AC volts range or lower on your meter reading, you can have intermittent crank/no-start conditions from your Renix Jeep. Some NEW CPSs (from the big box parts stores) have registered only .2 AC volts while reading the proper resistance!! That’s a definite no-start condition. Best to buy your CPS from Napa or the dealer. Sometimes on a manual transmission equipped Renix Jeep there is an accumulation of debris on the tip of the CPS. It’s worn off clutch material and since the CPS is a magnet, the metal sticks to the tip of the CPS causing a reduced voltage signal. You MAY get by with cleaning the tip of the CPS off. A little trick for increasing the output of your CPS is to drill out the upper mounting hole, or slot it so the CPS bracket rests on the bell housing when pushed down. Then, when mounting it, hold the CPS down as close to the flywheel as you can while tightening the bolts. Revised 07-30-2012 Link to comment Share on other sites More sharing options...
88MJNC Posted November 24, 2012 Share Posted November 24, 2012 i have something you can try i have had this problem since owning the truck for a lil over a year and its the only thing that works. Not a fix but on mine will get it back running for a week or a day just depends. Spray starter fluid into the air filter assembly there is a rubber hose that you can pop off and spray into hole and mine will fire off everytime. don't know why it just works on mine. Link to comment Share on other sites More sharing options...
