darkenfire Posted November 8, 2012 Posted November 8, 2012 I have an 89 comanche, putting a 95 HO in ... So I thought I had the starter relay wire marked ... or that it would be obvious or something, but .... none of the wires in that area are testing 12v when the key is held in start ... So can someone with a renix tell me what color it is, what it looks like, where it comes from, etc., etc. (Maybe even a pic?) If there is a connecter for it I may have disconected it there, so perhaps a description (or pic ;) ) of that ... I should have just unscrewed it from the starter and let it hang, but I think I either cut or disconnected it thinking I would splice the one coming from the 95 starter in ...
darkenfire Posted November 14, 2012 Author Posted November 14, 2012 My problem was that I didn't have a neutral safety switch plugged into the 89 harness at all, as I'm using the 95 for all of the drivetrain. So, I did have it labeled before I pulled the 89 engine and trans but wasn't getting 12v there after since the 89 wasn't seeing the NSS.
