Load Sensing Valve
Maybe not really tech, more of advise. Check your load sensing valve after you get new tires installed. I know mine was oriented correctly when I changed the dif fluid a year ago, then I took a pic for another thread and saw it was AFU. I put two and two together, I had new tires installed a month ago and they lifted the truck by the frame, must have extended the rod and when they lowered it the valve moved to this position.
This is what happened Jim.
Edit? :yes:
