flint54 Posted November 2, 2012 Posted November 2, 2012 I need to replace the rubber boot on the shifter housing, it's split wide open. I've got the shifter on the bench and cannot seem to get it apart. The FSM doesn't provide the detail, or at least I cannot find it. The lower shaft is squared where it goes into the upper shaft housing, and it appears there are metal clips pressing against that square. I've soaked it with penetrant and have tapped almost to the point of doing damage. Who can explain the secret? Thanks!
sloride Posted November 2, 2012 Posted November 2, 2012 Pickle Fork, vise and BFH. Clamp the assembly in a vise with black shift portion above vise just enough for a pickle fork to bite. Give pickle fork a couple good wacks with a hammer and she'll pop right off. I did it to my pukegoat shifter last night and to an AX-15 shifter assembly recently. Works like a charm.
MJRemi Posted November 2, 2012 Posted November 2, 2012 I've taken apart a few with a 1ft length of 2x2 or 2x4 and a deadblow hammer. Keep at it, it will come off.
flint54 Posted November 4, 2012 Author Posted November 4, 2012 RE: "Pickle Fork, vise and BFH" Got a vise, got a wide assortment of FH's, but thanks for the reason to go buy a tool I never had, a pickle fork. That did the job almost too easily. In another 21 years when I have to replace this boot again I will be well equipped!
Keyav8r Posted November 5, 2012 Posted November 5, 2012 I just took mine off to replace the boot, too. Put the lower part in the vise and used a short piece of 1" x 1" pine trim and a ball peen hammer. Surprised the heck out of me how easily it came off. I expected to have beat the crap out of it. Now to get it back together after I get the boot on the lower part.
