Butchershop Posted October 22, 2012 Share Posted October 22, 2012 If you were seeing double it would be an 8x8. This is real. Because sometimes four wheeling just isn’t good enough, Wild Boar Products has created the JK6 Wheeler custom Jeep. The California-based accessory specialist has stretched the frame of the four-door Wrangler and added a second Dana live axle in the rear. The two are connected by a 2.5-foot collapsible driveshaft that allows for full articulation, and power from the stock 3.6-liter V6 can still be sent to the front wheels providing 6x6 drive. Designed for long distance off-roading, the JK6 has a 65 gallon gas tank providing a range of over 1,000 miles and can be customized pretty much anyway you want it. The company is currently in talks with the Alaska State Police to build a few of them as wilderness patrol vehicles. Prices start at $69,000 and the sky’s the limit from there. You can even get a roof top tent in case you need a nap. A thousand miles is a long way to go between rest stops. Read more: http://www.foxnews.c...k#ixzz2A3uGWV7o Link to comment Share on other sites More sharing options...
86customanche Posted October 22, 2012 Share Posted October 22, 2012 :thumbsup: awesome Link to comment Share on other sites More sharing options...
gogmorgo Posted October 22, 2012 Share Posted October 22, 2012 Geez, no question about who that is in the distance when you see it coming... I'm curious as how it turns out if the AkSP do start using them. Link to comment Share on other sites More sharing options...
