bluzmj Posted October 20, 2012 Posted October 20, 2012 how of a big deal is it to change an mj with a 2.5 to 4.0 I have a 89 with a 4.0 only 61,000 mile but the body is shoot. I found one that is an 89 also with a 2.5 does run. I'm thinking about picking up if it an no big deal to change over. any in put would help Thanks
Eagle Posted October 20, 2012 Posted October 20, 2012 Many people have done it, but it is work. You have to change all the underhood wiring harness. If you're going from MJ to MJ, you have one advantage -- when people do this swap using an XJ as the donor vehicle, there's a some customizing required to make the brake lights function correctly.
mvusse Posted October 20, 2012 Posted October 20, 2012 It is not a one weekend job, so if I were to buy a 2.5 to be a body donor I wouldn't buy it unless the body and frame were pretty much completely dent and rust free.
bluzmj Posted October 20, 2012 Author Posted October 20, 2012 thats what I'm looking for, one with little rust. the only thing that worries me are the motor mounts on the unibody.
Eagle Posted October 21, 2012 Posted October 21, 2012 thats what I'm looking for, one with little rust. the only thing that worries me are the motor mounts on the unibody. ??? What's the worry? The motor mounts go in the same place.
