jimoshel Posted October 5, 2012 Posted October 5, 2012 Gonna pull a 249TC and swap a 242 in it's place. Think the shaft length and spline count will be no problem. Is there anything to look out for?
mvusse Posted October 6, 2012 Posted October 6, 2012 Correct me if I'm wrong, but I believe the 249 shift pattern is a little different from the 242, meaning you may need to change the shift gate as well. Also, if needed and if I remember correctly the input shaft can be swapped between similar year 231/242/249.
jimoshel Posted October 6, 2012 Author Posted October 6, 2012 It will be a complete swap. including shift linkage, gate, bezel.
jimoshel Posted October 6, 2012 Author Posted October 6, 2012 I have one from behind all 3. 42RE, 44RE and 46RE.
Comanche County Posted October 7, 2012 Posted October 7, 2012 Some will bolt right in, if they were behind the same transmission. But sometimes the input shaft needs to be changed out. For instance if you're putting a 242 from a AW4 behind a 46RE. http://kevinsoffroad.com/techarticles/Solitude%20242%20swap/249-242_swap.html http://www.cardomain.com/ride/771987/1998-jeep-grand-cherokee/page-3 http://cherokeekid5.tripod.com/t_case.htm http://jeephorizons.com/tech/tcase.html
