Ax15 Swap Back Up Light Wiring
RDAN1
I'm swapping in an AX15 to replace a BA10 and notice the backup light wiring for the AX15 is different from the BA10 (2 wire vs 4 wire). Can anyone advise the "fix" for this so the backup lights will work with the AX15 tranny? Or point me to a thread that shows how to deal with this? I've done a forum search but couldn't locate an answer. Thanks
OK here's a photo of the 2 switches. BA/10 on the left and AX15 on the right. So in order to get the backup lights to work with the AX15 tranny, all I need to do is splice in the 2 wries going to the original BA10 switch to the 2 wires on new Ax15 switch. Correct?
  • 2 years later...
That is also what I did.  I even cheaped out and grabbed the wiring from the ZJ I pulled my Bellhousing and TC for my swap, cut, soldered, shrink wrapped, and done.  The funny thing was, that actually fixed my reverse lights, which never worked on the BA-10 (I probably had a bad switch).  It's a really simple circuit, so I wouldn't sweat it too much.
