Parts In Southern Maryland
drcomanche
So, When I purchased my Comanche, it came with a BUNCH of extra parts, the lot of which I don't need. So I figured I would sell them off to whoever might need them on here. I cannot confirm if any of these parts work or not, but the lot of them look to be in working order.
By the way, all prices are negotiable. I'm just trying to get rid of the lot of them and if somebody needs a part, I'm not going to argue a few bucks for it
Ok, I have 2 NP231j transfer cases one is complete and the other is in pieces. I'm not sure if all the pieces are here for the dismantled one but the other one hand cranks with no noise or resistance. The speedometer gear is loose in the full one and, what looks like the vacuum connectors, has a broken male adapter and I would suggest cleaning it out before use. 150 each. If you happen to need parts for your TC let me know. I'll do the parts individually too.
1 Intake manifold, looks to be in fine condition. 20
1 mechanical fan and clutch, also looks to be in good condition. 20
1 electrical fan with shroud. Small crack in top corner of shroud. 20
2 electrical interior door handles w/power windows and locks. One lock switch is missing. I'm not sure if it works or not, but they look to be in OK condition. 5 both
2 outside door handles. 10 each
1 computer control unit. I'm not sure what it goes to or if it works. 10
2 door latch female adapters(the ones that go into the door) 5 each
1 full distributor. Has cap rotor and wires attached to it. Has definitely been used, as there are slight wear on the gear end. Also have ignition coil. 20
1 water pump w/out pulley. 20
2 chrome headlight surrounds 5 both
2 front non venting windows, complete with the seals and surrounds. 10 each
and 1 hood. The hood had a badge on it but that can be easily removed. It doesnt have any rust that I see, except on the brackets. 30
I also have a new Rough Country track bar that was put together and attempted to install, but it didn't fit, so it was never used. Still has box, all stickers bracket, bolts, heim, everything that came with it. 100
I also have 3 Interco Irok Bias Ply 36 inch tires with decent tread left on them, and one is mounted on a rim, but was popped before, so it now has a tube inside. 300 OBO
Many tan interior parts, just let me know what you need.
  • 4 weeks later...
I would like to ask you about the NP231 that's in pieces?
1) What is the mfg date? (should be on the round red tag as XX-XX-0XX)
2) Do you have the input gear?
3) if yes, is it 23 spline?
If #1 is 93 or older, and #2 and #3 are yes, I would like a couple measurements of it please,
to verify width of bearing land and length of nose.
THanks!
Any idea what lift heights the RC trackbar will work for?
It claims to be for 4-6 inches. I purchased it a while ago for my setup, but because I had a D44 and not the original D30 It was just barely too short to fit, and I have a 6 inch lift. Mounting hole to mounting hole, it goes 31 1/2 inches at it's shortest length, and can adjust a couple of inches from there outward.
As for the transfer case, I'll get back to you when I can, which will most likely be tomorrow.
Archived
