ILLXJ Posted September 12, 2012 Posted September 12, 2012 I just finished a 5-speed to AW4 swap & am about to start the wiring harness swap. I know the AW4 computer is normally mounted inside the cab under the dash, is there any reason it can't be mounted under the hood? TIA' JIM.
ParadiseMJ Posted September 12, 2012 Posted September 12, 2012 I would think it was mounted inside the cab to avoid heat, moisture, vibration. I put mine in the stock location when I did the swap...getting the wiring in there was kind of a pain...but it got done. Why would you not want it in the cab??
ILLXJ Posted September 13, 2012 Author Posted September 13, 2012 It's not that I don't want it in the cab, but since I hate wiring, I figured the easier the better. JIM.
cruiser54 Posted September 13, 2012 Posted September 13, 2012 You'd probably be just fine doing that. Keep it high and dry.
