ILLXJ
ILLXJ's Achievements
  1. ILLXJ
    1J7FT26S0NL189841
    1992 Base 4.0L automatic 2 WD Build date 1/92 Clay county IL Red with grey interior
  2. I got mine at NAPA. I would post the part #, but I don't have it here at work. JIM.
  3. It's not that I don't want it in the cab, but since I hate wiring, I figured the easier the better. JIM.
  4. I just finished a 5-speed to AW4 swap & am about to start the wiring harness swap. I know the AW4 computer is normally mounted inside the cab under the dash, is there any reason it can't be mounted under the hood? TIA' JIM.
  5. I going to assume these are for the front. If so the minor is the parking lamp, the major is the turn. Not sure of the wire colors on the MJ, but the minor should be the same as the side marker. JIM.
  6. I have one for a SWB, but I'm in ILL. JIM.
  7. Yes 2 different trucks. The 87 is in the top pic. Here is the 89: And before any body ask, I have cleaned it up since I took the int. pic. Since I have a 5.5 day weekend I plan on changing the fluid in the trans. & rear ends of both. Also going to try to straighten the rear bumper on the 87. JIM.
  8. We just picked up an 87 Base model. 2.5L/4 speed/2wd with out P/S or A/C. What should be the factory gear ratio & the factory tire size? We can't read the door sticker, it's faded out. The 89 I have is a 4L/5 speed/2wd. I would like to know: #1 What is this? It is on the fender behind the air box. #2 What is this relay for? On the core support in front of the air box. #3 Where is the fill plug on the trans.? Pretty sure it is the BA-10. Thanks, JIM.
