Why such a small post window?
knever3
I am sure you are aware of the limitations of the small window that you can type in. Why does it get so far down and then it just wiggs out and doesn't show the cursor and you can't see what you are typing? It's very bothersome if you have a large post. I normally have to make a word document then copy and paste into the post window so I can make a long'ish post.
Thoughts?
Using Mozilla Firefox on Linux I have no such limitations. The window is 130 characters across by 16 lines. After I exceed 16 lines a scroll bar appears on the right hand edge.
X2.
I've been on some other forums, and this is by far one of the easiest/biggest reply pages. Jeepforum goes as far as putting actual pics in when you hotlink (if you use their button), and that clutters and makes things real small quick.
Rob
