drcomanche Posted August 22, 2012 Posted August 22, 2012 So, I purchased a new IAC for the Comanche, but when installed, it idles at 3000 rpm off the bat. I looked at my old one and it seems to be stuck in the open(?) position, with the plunger sticking all the way out. With that one installed, it works ok. The idle stutters and sometimes idles at 900 and other times 600. It definitely misses a lot, but I'm not sure if that has to do with the IAC or the age of the vehicle. And it gets pretty terrible gas mileage, even for the tires. Any ideas? On a may be related side, the truck does backfire when shifting at mid to high rpm, and I still haven't been able to change my O2 sensor.
cruiser54 Posted August 23, 2012 Posted August 23, 2012 Plunger sticking out is closed positon. Do you have tune up issues? IAC will not cause a miss.
drcomanche Posted August 23, 2012 Author Posted August 23, 2012 I have replaced: Spark plugs Cap Rotor Ignition coil injectors Air filter Fuel filter Mass air sensor Exhaust headers And while I did the headers I cleaned all my ports and the intake manifold, including the channel for the IAC(not with it in, of course).
cruiser54 Posted August 23, 2012 Posted August 23, 2012 No new igniton wires? Ever refreshed all your grounds or checked your sensor ground circuit with a meter?
drcomanche Posted August 24, 2012 Author Posted August 24, 2012 sorry, forgot about the wires, but yes, they have been replaced, and I have sanded and made sure all my grounds have good contact points. At this point, after some research, I have vaguely heard that the new IAC requires a certain setup to "tune" it? I never hear about it, but maybe somebody on here knows how it works? As for the rough idle and misses, I'm think MAP sensor or TPS.
cruiser54 Posted August 24, 2012 Posted August 24, 2012 No real need for the ECU to learn what the IAC is doing on a Renix.
drcomanche Posted August 24, 2012 Author Posted August 24, 2012 It isn't a Renix engine, though. The Comanche may be an 88 but the entire drivetrain is 94 cherokee, including engine.
