pug Posted August 22, 2012 Posted August 22, 2012 Throwout bearing went out no big deal. I did notice a lot off oil in bellhousing clutch disk is dry rear main seal is dry. Transmission shifts into gear smooth. The main shaft that goes into back of the motor has a littlle play in it would this cause a worn seal. thanks
jimoshel Posted August 22, 2012 Posted August 22, 2012 All input shafts on standard transmissions have a little play. When they're installed the snout is in the pilot bushing and keeps it steady,. Normal wear will do a seal in. Are you referring to the crankshaft rear seal or the transmission front seal?
pug Posted August 22, 2012 Author Posted August 22, 2012 transmission front seal i guess because whole inside of bellhousing is coverd with oil.
Geonovast Posted August 22, 2012 Posted August 22, 2012 The bearing retainer cover gasket could simply be leaking.
pug Posted August 22, 2012 Author Posted August 22, 2012 Thats what i was thinking also can you buy the spring that goes on the throw out bearing or do they com with the new clutch kit. thanks
Geonovast Posted August 22, 2012 Posted August 22, 2012 What spring? Are you external or internal slave?
pug Posted August 22, 2012 Author Posted August 22, 2012 External slave. There is some springs that hold the throwout bearing to the fork inside the bellhousing
Geonovast Posted August 22, 2012 Posted August 22, 2012 Those should come with a new throwout bearing.
pug Posted August 23, 2012 Author Posted August 23, 2012 The spring i am talking about is a fork pivit spring. Goes on opposit side of external slave cylinder on the inside of fork. Hope i didnt make this confusing.thanks
