rmontes Posted August 14, 2012 Share Posted August 14, 2012 can a cherokee, tj 4cil 97+ parts can be use in a comanche 2.5 such as engine harness, firewall harness,all sensor's, dash, intake manifold? :dunno: :???: Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 14, 2012 Share Posted August 14, 2012 Don't think so. Link to comment Share on other sites More sharing options...
Comanche County Posted August 14, 2012 Share Posted August 14, 2012 The engine and wiring won't be a plug and play install, you're looking at a custom harness. Probably best just to find a later XJ with the 2.5. But, if you've got the engine available and that's all you've got to work with, I'd call up Centech or Painless and get a quote from them. They can make a custom harness for you. http://www.centechwire.com/catalog/jeeps/wiring.html http://gopainlesswiring.com/ I do like the TJ steering wheels, I imagine the steering wheel itself could be made to work on a later Chrysler XJ steering column. Sir Sam is the resident expert on steering wheel wiring. Link to comment Share on other sites More sharing options...
