can a cherokee, tj 4cil 97+ parts can be use in a comanche 2.5 such as engine harness, firewall harness,all sensor's, dash, intake manifold? :dunno: :???:
coming out nice! for the xj dash you have to replace the bracket from the xj to the mj? or can you use the one on the mj? I'm about to change my dash to a xj.
:cheers:
it happen to once I spray some WD-40 on the pulley it stop but next day it started to make noise again I bought this spray for special for serpentine Belts spray it and turn on the engine it was still making noise but like 5 10 minutes after it completely stop making noise until today.
I bought a complete xj 99 dashboard and steering column my question is when i do the swap, i just swap the vin from the old one to the new one or what do i do? :dunno:
my uncles mj with a 2000 xj conversion 4.7 stroker and commander headlights. It's easy to modify the header panel, just have to do some cutting on the bottom so it could fit perfect.
here's an xj
