COFFMAN Posted August 7, 2012 Posted August 7, 2012 Could someone please tell me the lenght of the D44 diff housing ( Rear ) WMS to WMS Priceing a new Danna crate axel but only cum in one lenght 64.84in Thanks in advance for any help Also is the front the same lenght as the rear Yes i can use a tape messure but my MJ is 6000km away :waving:
MJRemi Posted August 7, 2012 Posted August 7, 2012 Here's a post on the same question regarding D35 but the width should be the same. viewtopic.php?f=2&t=36372
mvusse Posted August 7, 2012 Posted August 7, 2012 Cherokee/Comanche axles are in the 60-61 inch range. I have a D44 rear out of a 79 F100 you can have for $100, but it's 67" wide.
COFFMAN Posted August 8, 2012 Author Posted August 8, 2012 Cherokee/Comanche axles are in the 60-61 inch range. I have a D44 rear out of a 79 F100 you can have for $100, but it's 67" wide. Thanks mvusse, but if i was going to cut and shut a rear axel housing i would build a 9inch Henry Will probley go D44 front and rear at this stage a new crate axel will be out of the question being to wide, And @ approx $700.00 to shorten to expencive. One up side of the crate axel was the electric locker & if the lenght was right i could justify the cost :wavey:
