NTXMancheman Posted July 16, 2012 Posted July 16, 2012 i have a cherokee 44 going under the manche. what is the parts list i need to do soa i will be welding it myself. I'm used to coil from my tj so i have nooooo idea what goes into this, if someone could give me a complete part list down to the nuts and bolts that would be great
skidoo_j Posted July 16, 2012 Posted July 16, 2012 spring perches, and u-bolts. I also added new shock mounts welded to axle but you can modify and use the oem plates.... and new shocks. you'll have to measure for length as what you get depends on where how you mount the axle end and if you keep the factory mount on the frame. I used ones from a company called http://www.ruffstuffspecialties.com/cat ... pKits.html they're a bit expensive, but they were the thickest steel i could find, and the perches are some of the longest i found (helps reduce axle twist. I did grind the cut out deeper when doing mine because i wanted to minimize the lift. Good luck. there's ton's of people that have done it on here already .... take a few minutes. I think i even have several posts when doing mine of what i did. others are way more detailed. search d44 SOA
Eagle Posted July 16, 2012 Posted July 16, 2012 IMHO the stealth deal of the millennium is right from Jeep -- the Mpoar Performance Catalog. The leaf spring perches are extremely heavy duty and unbelievably cheap. http://www.mopar.com/assets/pdf/perform ... Brakes.pdf Scroll down to page 10, top left. When you call a dealer for a price, the part number is for a pair, so you only buy quantity one (1).
NTXMancheman Posted July 17, 2012 Author Posted July 17, 2012 thanks guys i ordered the rough stuff kit
