mpace6a Posted July 5, 2012 Share Posted July 5, 2012 Gotta replace 2 brake lines on my truck, and both go behind the gas tank. One for sure goes to the load sensing..thing. Wondering if I should drop the tank, pull the bed, or just bypass the load sensor? Link to comment Share on other sites More sharing options...
Eagle Posted July 6, 2012 Share Posted July 6, 2012 After having one explode in a panic stop, I do NOT trust the height sensing valve. Replacements aren't available, so deleting it from the truck that suffered the failure was a no-brainer. However, I like having rear brakes, and I plan to eliminate the rear height sensing valve on each MJ as I progressively get them roadworthy. Link to comment Share on other sites More sharing options...
Pete M Posted July 6, 2012 Share Posted July 6, 2012 there's no need to copy the factory routing. I ran a new line straight back along the bottom edge of the frame rather than tuck it way up there to rot again. :thumbsup: Link to comment Share on other sites More sharing options...
mpace6a Posted July 6, 2012 Author Share Posted July 6, 2012 So just bypass the height sensing valve and run it like normal brake lines? sounds so much easier! :clapping: Link to comment Share on other sites More sharing options...
