TooTall Posted June 28, 2012 Author Share Posted June 28, 2012 Better bigger pict!!!! i will get more soon !!! Link to comment Share on other sites More sharing options...
mountainman Posted June 28, 2012 Share Posted June 28, 2012 Fill that front axle with LE1605. That will help keep that gear set alive. :) http://products.lelubricants.com/item/a ... in=keyword fluid is everything when it comes to severe service on a gear set. Link to comment Share on other sites More sharing options...
TooTall Posted June 28, 2012 Author Share Posted June 28, 2012 thx for the info!! its got lucas but I'm willing to try other things also ..i just no Lucas and i trust it ! :jump: Link to comment Share on other sites More sharing options...
mountainman Posted June 28, 2012 Share Posted June 28, 2012 No prob. i specialize in being the "solutions guy" And one of my biggest studies and research has been on ring and pinion life, especially on weak units. I am one of the top s2000 builders in the country. Well the s2000 has a history of differential failures. Fluid IS the problem. If the fluid is not the proper stuff, then it allows metal to metal contact. Then stuff misaligns, I'm talkin by thounsandths of an inch and the unit does a pufferfish effect.. then its over. It swells enough to skip a tooth, or shall i say... move the load out to an undesired portion of the tooth/teeth and BOOM there goes your ring. This is the case in most final drives. I have also drag raced my entire life. The difference between an exploded final drive and one that holds is always in the setup and the fluid. Units that others say are "known to be weak" are simply not being properly set up for the intended use. That extreme pressure gear oil i showed you, has solved about 90% of our differential failures in the s2000 world. 75/90... BOOM. extreme pressure 90/110. stays in one piece. Guys were breaking differentials in as little as 9 clutch dumps on the street. I had over 3500 7k rpm clutch dumps (drag race starts) on my diff when i sold the car. I proved the fluid had solved the issue. This fluid is now the s2000 industry standard. :) Hope this helps the comanche community. Its what ill be running in my D30 when i do a non CAD upgrade and 33s or 35s Link to comment Share on other sites More sharing options...
TooTall Posted June 28, 2012 Author Share Posted June 28, 2012 Nobody see it??? Well I'n proud of it .. Not braggin but proud!!!! Lots of work a year to be exact! And finally!! Now I am having to replace the gas tank and pump because when we blasted the tank and por 15 it we left holes!! And new pump is allways good when replacing tank!!!! Link to comment Share on other sites More sharing options...
TooTall Posted July 2, 2012 Author Share Posted July 2, 2012 Me and MY Brothers Rigs! Link to comment Share on other sites More sharing options...
TooTall Posted July 10, 2012 Author Share Posted July 10, 2012 Link to comment Share on other sites More sharing options...
TooTall Posted July 10, 2012 Author Share Posted July 10, 2012 I'm IN LOVE! :clapping: Link to comment Share on other sites More sharing options...
TooTall Posted July 10, 2012 Author Share Posted July 10, 2012 just a few more picts while its fresh!!!! :bowdown: Link to comment Share on other sites More sharing options...
H3RESQ Posted July 11, 2012 Share Posted July 11, 2012 Good looking Mj :cheers: Link to comment Share on other sites More sharing options...
lifted_xj Posted July 11, 2012 Share Posted July 11, 2012 I'm digging the raptor finish, good looking truck. Link to comment Share on other sites More sharing options...
TooTall Posted July 11, 2012 Author Share Posted July 11, 2012 thx guys!! :cheers: to you !! Its raptor underneath bed and inside cab,, not on outside that is Xstreme Liner and its a pain to spray also but its pretty durable and raptor is about the same price!! I think either one is good tho as ive sprayed other stuff with them both but raptor is much finer texture then Xsteme even when theres no additives!!I like it and I'm a sucker for black!!! Link to comment Share on other sites More sharing options...
