Hey guys I just bought my brothers decked out Comanche it's a 1991 4x4 bobbed baby I will get Picts soon anyhow it has slow blinkers and no side markers also the gauges are like oil light ,temp are blinking ..any ideas what to check for???
For the blinking I would change the flasher,
if you check out the fuse box they are the circular relays, should be 2 of them.
One is the turn signals the other is the hazards,
if your hazards are flashing correctly you can check if its just the flasher by switching the two and if the turn signals are better and the hazards are slow then you have your problem identified and you can buy a new flasher.
that other stuff someone else can chime in on.
The grounds in the front turn signal/parking light sockets are bad, they are feeding power back to your cluster. Change your sockets, I think most of us have been through that.
