86custom Posted June 24, 2012 Share Posted June 24, 2012 Howdy, I was known as XJDUMMY from before, and tried to get on here but I havent been on for a while. Also we sold the XJ anyway, so I'm now 86custom. :cheers: Any way :roll: My sway bar bushing broke yesterday, luckily I had a spare stock rubber one. Should I replace all of my rubber bushings to polyeurathane? What or who makes the best kit for it? :wrench: 1986 Comanche long bed 2.5, 5 speed, stock heigth (for now) thanks Link to comment Share on other sites More sharing options...
ParadiseMJ Posted June 24, 2012 Share Posted June 24, 2012 I prefer rubber all around EXCEPT sway bar bushings and track bar bushings. Rubber is more flexible, theoretically less vibration transferred from road to person. Poly is easier to install, usually, and will hold tighter without too much movement/flex. :wrench: Link to comment Share on other sites More sharing options...
Pete M Posted June 25, 2012 Share Posted June 25, 2012 do you want your old account back? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 25, 2012 Share Posted June 25, 2012 I prefer rubber all around EXCEPT sway bar bushings and track bar bushings. Rubber is more flexible, theoretically less vibration transferred from road to person. Poly is easier to install, usually, and will hold tighter without too much movement/flex. :wrench: :agree: ^^ The only poly bushings I have are on the sway bar end links. Charlie, your piston avatar is mesmerizing. Obviously a 60* V6 piston though. :yes: Link to comment Share on other sites More sharing options...
ParadiseMJ Posted June 25, 2012 Share Posted June 25, 2012 It was the only moving piston I could find. Link to comment Share on other sites More sharing options...
86custom Posted June 26, 2012 Author Share Posted June 26, 2012 do you want your old account back? Oh great Comanche GURU :bowdown: No thank you. :jump: Link to comment Share on other sites More sharing options...
86custom Posted June 26, 2012 Author Share Posted June 26, 2012 I prefer rubber all around EXCEPT sway bar bushings and track bar bushings. Rubber is more flexible, theoretically less vibration transferred from road to person. Poly is easier to install, usually, and will hold tighter without too much movement/flex. :wrench: Um sorry for the stupid question, What are track bar bushings? :???: Link to comment Share on other sites More sharing options...
Pete M Posted June 27, 2012 Share Posted June 27, 2012 it's the bushing in the track bar (on the axle end). :thumbsup: Link to comment Share on other sites More sharing options...
