Trifecta1988 Posted June 19, 2012 Share Posted June 19, 2012 I have a 1988 Comanche and here recently it has started acting funny. When I start up the RPMs jump real high and then come down. Also when I put it in gear and press the gas pedal it dies. I am confused as to what can be causing this. I am pretty sure my EGR valve is bad, but I am not sure if that would make it act like this. Any suggestions would be great. :huh???: Link to comment Share on other sites More sharing options...
xjrev10 Posted June 19, 2012 Share Posted June 19, 2012 Most likely its a vaccum issue. I would replace all the vacuum lines. You can get both 'harnesses' from rock auto for less then 25 bucks. Link to comment Share on other sites More sharing options...
Trifecta1988 Posted June 19, 2012 Author Share Posted June 19, 2012 RE: xjrev10, Thanks I will look into that. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 19, 2012 Share Posted June 19, 2012 EGR is a vacuum leak when it's sticking open. Probably should address that first and take it out of the equation. Link to comment Share on other sites More sharing options...
