350cjmass Posted June 16, 2012 Posted June 16, 2012 Hello everyone, I've owned my Comanche for roughly 6 months & have found this forum to be a great resource. Just wondering if anyone has replaced the "idiot-light" cluster with an actual gauge cluster; only to find the tach is way off? I've got a 4.0 & installed a "unknown" cluster... at idle the truck is reading MAYBE 0-100?? Rpm. It's working properly, adjusts with engine speed; but is reading rather low. I dissassmbled the cluster and found the adjustment screw, but can't find if I'll need to replace the resistor if in fact my cluster came from a 4-banger?? Will adjusting the potentiometer screw correct my issue? Or should i look to replace the resistor/get another tach? Thanks in advance for any and all help. :bowdown:
jimoshel Posted June 17, 2012 Posted June 17, 2012 Try adjusting the pot first. That's why it's there.
350cjmass Posted June 17, 2012 Author Posted June 17, 2012 Thanks for the good words....I'll hook up a "real" tach tomorrow and let y'all know. I just didn't want to screw with it too much in case it was perfectly setup for a 4. I plan to start posting a build soon; just about done with my "Spotweld-Nightmare"! Replacing the entire floor & upgrading every single suspension/steering componebt has been quite fun..lol...Not even close to my CJ or XJ hours yet; BUT, still got plenty to go:-) Thanks again, Mike
Geonovast Posted June 17, 2012 Posted June 17, 2012 If the tach was set for a 4, and you have it on a 6, it would actually read high, not low. The needle was probably fubared at some point. You'll probably be alright just swapping out the tach.
