my88comanche Posted June 15, 2012 Share Posted June 15, 2012 I'm looking for a 2.5l motor. The one on my truck gave out with a cracked block beyond repair. I'm located in south Texas and have looked at junk yards of over a 100 mile radius and have realized how rare these trucks are and how hard it is to find parts for them. I've been considering dropping a 4.0l 6 cyl motor since they are more common but I don't know if it'll bolt on to the 4 speed manual trans or if i'll have to swap out tranny as well....if anyone has a 4 cyl 2.5 for sale let me know. If anyone has info about dropping in a 4.0, please let me know. Thanx. Link to comment Share on other sites More sharing options...
jimoshel Posted June 15, 2012 Share Posted June 15, 2012 Got a couple 2.5's but I think shipping would be prohibitive. Let you decide. Got a couple cores, $50 each. Got a good running low mileage out of a '96 XJ. $500 stripped or $600 complete. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted June 16, 2012 Share Posted June 16, 2012 To swap in a 4.0, you will need a similar year COMPLETE donor Comanche or Cherokee. Since Cherokee donors are hugely more common, they will be easier to find but won't have everything youll need.... Meaning youll need a new rear drive shaft from a similar Comanche or have one made. I say get a complete donor because the engine, trans, engine compartment wiring, under dash wiring, instrument cluster, transfer case shift linkage, radiator, core support...... and probably some other stuff I can't think of, need to be swapped over for a 4.0 swap. Its a HUGE job. Keep looking for a 2.5, or search online for a complete rebuilt unit from any number of different manufacturers. You could also try http://www.car-part.com and search on there for a good used one in either a Cherokee, Dakota, or a Wrangler. Get it and swap over all your existing intake, exhaust and accessories. The models from 90 and older and 91 and newer have different operating systems, but from what I know, the long blocks are all the same relatively speaking. Good luck with your search. Link to comment Share on other sites More sharing options...
Eagle Posted June 16, 2012 Share Posted June 16, 2012 I have a 2.5L that came out of a '94 (approximately) Wrangler, so it's set up for a Mopar injection rather than Renix. It was given to me and I have no use for it. If you want it, it's yours for the shipping. I can probably scrounge a pallet somewhere. I don't know if it runs or not, but I do know it was removed to make space for a Chevy V8 conversion, so I believe it was running when pulled. IIRC it has a Chrysler 3-speed auto tranny bolted to it -- you can have that, too, or save the weight if you don't need it. Link to comment Share on other sites More sharing options...
