xjrev10 Posted June 1, 2012 Posted June 1, 2012 My 91... The Jeep runs funny till the coolant temp gets to 210. I can take off down the highway and it constantly looses power causing a 'bucking' motion in the truck. When the truck is idling cold, it will act like its going to shut down but it usually doesnt just looses most of the RPMs and then revs back up. I have been driving it quite a bit, does it everytime. I also get a CEL when it starts jerking, loosing power on the highway. But once the rig warms up to full operating temp, shes runs great. :hmm: Any ideas? The only things I have done to it is change the oil and fuel filter. The cap and wires looks new'er'. Also, I don't have a 91+ owners manual to learn how to check out what the CEL means.. Anyone got any input for that?
HOrnbrod Posted June 1, 2012 Posted June 1, 2012 Have you checked for fault codes? http://www.comancheclub.com/forums/viewtopic.php?f=9&t=29857
xjrev10 Posted June 2, 2012 Author Posted June 2, 2012 Have you checked for fault codes? http://www.comancheclub.com/forums/viewtopic.php?f=9&t=29857 That's the info I was looking for! Thanks Don.
xjrev10 Posted June 19, 2012 Author Posted June 19, 2012 36 Air switch solenoid circuit. Air switch solenoid circuit (non-turbo) or the waste gate solenoid on turbocharged models This is what I got. What do I change? (copy/paste from the thread)
johnnyc Posted June 19, 2012 Posted June 19, 2012 Sounds like the IAC unit located on the throttle body.
HOrnbrod Posted June 19, 2012 Posted June 19, 2012 I remember reading over on Allpar that a bad ASD relay could throw the 36 fault code and not throw the ASD fault code 42. Try swapping out the ASD relay with another similar relay in the PDC (Power Distribution Center), right side engine bay, then clear the codes by disconnecting the battery. Can't hurt.
xjrev10 Posted June 19, 2012 Author Posted June 19, 2012 Sounds like the IAC unit located on the throttle body. clean or replace? I remember reading over on Allpar that a bad ASD relay could throw the 36 fault code and not throw the ASD fault code 42. Try swapping out the ASD relay with another similar relay in the PDC (Power Distribution Center), right side engine bay, then clear the codes by disconnecting the battery. Can't hurt. Going to go give this a go now.
johnnyc Posted June 19, 2012 Posted June 19, 2012 You can try cleaning the IAC, but they usually get pretty gunked up. Once, I had one so bad that when I took it off, the pintle and spring came out in pieces.
xjrev10 Posted June 20, 2012 Author Posted June 20, 2012 I am happy to report changing out the relay worked! I had no issue coming to work tonight. This jeep is my new DD so we shall see if it holds up. I plan to change the IAC anyway.
xjrev10 Posted June 21, 2012 Author Posted June 21, 2012 Ok.. The relay did fix 75% of the problem. It still chuggs but just a tiny bit. Its managable and did get the truck back on the road to DD status. I'm going to change the IAC. And the CEL light came back. Have yet to check to see if its the same code.
