foreman1063 Posted May 11, 2012 Share Posted May 11, 2012 Got a 93 XJ that I've been working on. The fuel pump was howling terribly and the gas gauge was stuck on E, with the low fuel light on. I swapped in another gauge cluster to verify the gauge wasn't the problem and it had exactly the same issue, so the sending unit must be bad. I ordered a a new pump assembly and got it installed today. The new pump is nice and quiet but the gas gauge is still stuck on E with the low fuel light on. :wall: I wish I would have tested the new sending unit before installing, at least if it is bad I could have saved myself the aggravation of installing it and removing it again. If the sending unit tests good any good ideas what the problem may be? Link to comment Share on other sites More sharing options...
ComancheKid45 Posted May 11, 2012 Share Posted May 11, 2012 Check the grounds for the sending unit. Thats where i would start before tracing wires ;) Link to comment Share on other sites More sharing options...
