You may need to change the ZJ CV pinion coupling over to a U-Joint yoke. Those CVs can be buggers to get off btw. Remove the eight (I believe) 8mm bolts, then liberally apply PB or what ever, then curse some, then grab a BFH. If you yank the drive shaft too hard, the CV can come apart.
Its also LP.
