jimoshel Posted May 2, 2012 Share Posted May 2, 2012 Will a D30 from a Grand Cherokee, early '90'S direct swap with a early '90's XJ? :dunno: Link to comment Share on other sites More sharing options...
Jeepman Posted May 2, 2012 Share Posted May 2, 2012 Yes... Link to comment Share on other sites More sharing options...
Comanche County Posted May 2, 2012 Share Posted May 2, 2012 You may need to change the ZJ CV pinion coupling over to a U-Joint yoke. Those CVs can be buggers to get off btw. Remove the eight (I believe) 8mm bolts, then liberally apply PB or what ever, then curse some, then grab a BFH. If you yank the drive shaft too hard, the CV can come apart. Its also LP. Link to comment Share on other sites More sharing options...
