ParadiseMJ Posted May 2, 2012 Posted May 2, 2012 You may need a different Transfer Case or change the input gear with the higher spline count.
hick92 Posted May 2, 2012 Author Posted May 2, 2012 ok so the trans and tranfer case will bolt right in and also what would make the tranfer case stay locked in 4wd low
