tralfaz Posted April 26, 2012 Share Posted April 26, 2012 I want to replace my front sway bar bushings however I do not know how to determine the sway bar diameter in order to obtain the correct bushing size. Any help will be greatly appreciated. Thank you! :help: Link to comment Share on other sites More sharing options...
RDAN1 Posted April 26, 2012 Share Posted April 26, 2012 I want to replace my front sway bar bushings however I do not know how to determine the sway bar diameter in order to obtain the correct bushing size. Any help will be greatly appreciated. Thank you! :help: Since the bushing are in several MM sizes, the best method may be to measure the sway bar with digital calipers. That's what I did and I got the correct size bushings with no problems. Link to comment Share on other sites More sharing options...
05mxdiesel Posted April 27, 2012 Share Posted April 27, 2012 I just replaced mine yesterday, 89 4x4 4.0 was 26mm. Link to comment Share on other sites More sharing options...
Eagle Posted April 28, 2012 Share Posted April 28, 2012 I want to replace my front sway bar bushings however I do not know how to determine the sway bar diameter in order to obtain the correct bushing size. Any help will be greatly appreciated. Thank you! :help: Since the bushing are in several MM sizes, the best method may be to measure the sway bar with digital calipers. That's what I did and I got the correct size bushings with no problems. That'll work, but the sway bars are not made to a tolerance of .001 inch. I just use a set of open end wrenches. Find the one that just fits around a straight section of the bar. IIRC, there are three possible sizes. Link to comment Share on other sites More sharing options...
