Blue88Comanche Posted April 9, 2012 Share Posted April 9, 2012 Dad and I where replacing the LCAs and they where being stubborn as usual so Dad came up with this idea. He used his small bottle jack to move the axle until it lined up properly and we where able to push the bolt in without any problems. this is one way to do it, if you have another way that works just as well please share :yes: those where actually our extra set we ended up needing to use that weekend. because it had been raining all week the ground gave way and the jeep fell of the jack stands. (and the stands where on pads) Link to comment Share on other sites More sharing options...
LobsterThief Posted April 10, 2012 Share Posted April 10, 2012 I used a ratchet strap. Different method, same result :banana: Link to comment Share on other sites More sharing options...
bighause Posted April 25, 2012 Share Posted April 25, 2012 Ratchet straps are my preferred method as well but the jack would give more leverage I couldn't imagine being under a vehicle on jack stands that were on grass! No way! Lucky no one got hurt. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted April 25, 2012 Author Share Posted April 25, 2012 the jack stands where on concrete pads, not directly on the grass. i tried ratchet straps when i did the LCA on my Comanche it worked but it was a pita Link to comment Share on other sites More sharing options...
carnuck Posted June 7, 2012 Share Posted June 7, 2012 Any surface that is soft tends to sink in. I have a cracked skull (knocked my right eye out of socket) from doing this on concrete when the Duvall quake of '95 hit. Even sudden wind gusts can push things around more than you would think. Link to comment Share on other sites More sharing options...
