My Comanche doesn't appear to have a trailer light plug, though it has a hitch. Before I go tearing into the wiring to pull out signals and brake lights I thought I would check if there's an existing connector in the harness for them that I can jump into instead. Anyone encounter this?
There's possibly a factory connector you can open up and insert a Hoppy harness, but the MJ uses the taillights as combination stop, tail & turn signal lights, just like a simple 4-wire trailer. I just used quick taps to splice into the wires. No logic box adapter needed on the MJ (unlike the XJ).
X2 did this on both of mine ----
