Shane Posted March 29, 2012 Share Posted March 29, 2012 Question is in the title. Can I put gauges out of a 91+ in a 89 MJ. I know that ther is a difference in color and speedo cable, but what will make it work? The reason I wanted to know is because I have the column shift and made the cut for the indicator to go on the gauges, but all I'm finding are the ones in 91+. Could I simply remove the gauges from the white unit (without removing the needles) and put them in the blue one? Any advice is appreciated Link to comment Share on other sites More sharing options...
Shane Posted March 30, 2012 Author Share Posted March 30, 2012 :hmm: Any ideas??? :idea: Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 30, 2012 Share Posted March 30, 2012 Question is in the title. Can I put gauges out of a 91+ in a 89 MJ. I know that ther is a difference in color and speedo cable, but what will make it work? The reason I wanted to know is because I have the column shift and made the cut for the indicator to go on the gauges, but all I'm finding are the ones in 91+. Could I simply remove the gauges from the white unit (without removing the needles) and put them in the blue one? Any advice is appreciated No. "Could I simply remove the gauges from the white unit (without removing the needles) and put them in the blue one"? To translate, the "white unit" is the HO gauge cluster housing; the "blue one" is the Renix. Three of the gauges are different and use different inputs, the clusters have different mounting bosses for the gauges, the 91+ is an electronic speedo - not cable driven, the printed circuit foil is entirely different between the two gauge pod housings, the fuel gauge is a different polarity, etc. etc. No way. Link to comment Share on other sites More sharing options...
Shane Posted March 30, 2012 Author Share Posted March 30, 2012 Question is in the title. Can I put gauges out of a 91+ in a 89 MJ. I know that ther is a difference in color and speedo cable, but what will make it work? The reason I wanted to know is because I have the column shift and made the cut for the indicator to go on the gauges, but all I'm finding are the ones in 91+. Could I simply remove the gauges from the white unit (without removing the needles) and put them in the blue one? Any advice is appreciated No. "Could I simply remove the gauges from the white unit (without removing the needles) and put them in the blue one"? To translate, the "white unit" is the HO gauge cluster housing; the "blue one" is the Renix. Three of the gauges are different and use different inputs, the clusters have different mounting bosses for the gauges, the 91+ is an electronic speedo - not cable driven, the printed circuit foil is entirely different between the two gauge pod housings, the fuel gauge is a different polarity, etc. etc. No way. Hey man, thanks alot!!!! I read in jpmagazine that 99+ manifold will directly bolt to the renix one and give 10 - 25 more HP. Is that tru? Is it really that simple or will something else have to be changed? Link to comment Share on other sites More sharing options...
Eagle Posted March 30, 2012 Share Posted March 30, 2012 Hey man, thanks alot!!!! I read in jpmagazine that 99+ manifold will directly bolt to the renix one and give 10 - 25 more HP. Is that tru? Is it really that simple or will something else have to be changed? Bolt DIRECTLY to the Renix head and give 10 to 25 more horsepower? Another "No." Will the later manifold bolt on? Yes. Do the ports line up? No. The ports are shaped differently and the newer heads have the ports located higher, so if you just bolt a late model manifold to a Renix head you have a massive port mismatch, and IMHO there's no way that can increase the horsepower. And, assuming you're talking about the intake manifold, the throttle body and the TB mount are different, so you have to either adapt the Renix throttle body to the late model manifold, or adapt the manifold to the Renix throttle body. Link to comment Share on other sites More sharing options...
johnj92131 Posted March 30, 2012 Share Posted March 30, 2012 As you have been told, you need to use a 90 or earlier gauge cluster in your 89 column shifter truck. I have been contemplating doing the same swap in my 91 column shifter truck. For me the "best" option seems to be get tech decal to cover the old fuel guage. That would let me keep my column shift gear indicator. Then replace the tach face with the old fuel face (now with a tach decal). My current problem is where to get a decal for the tach. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 30, 2012 Share Posted March 30, 2012 I have been contemplating doing the same swap in my 91 column shifter truck. For me the "best" option seems to be get tech decal to cover the old fuel guage. That would let me keep my column shift gear indicator. Then replace the tach face with the old fuel face (now with a tach decal). My current problem is where to get a decal for the tach. That would work for the 91-92. Good plan. Check out this thread: http://gojeep.willyshotrod.com/Whitebground.htm You would have to change all the gauge faces, but could be nice. Link to comment Share on other sites More sharing options...
johnj92131 Posted March 30, 2012 Share Posted March 30, 2012 Don, Have been aware of GoJeep's decals. Suspect that is the best solution (especially for the price). Not sure how the white line at the bottom of the tack will match to the shift indicator cut out. Guess we could raise it up just a fraction of an inch. Well, I just broke down and ordered the stock decals in white from GoJeep. Now I have no excuses to not do the cluster swap! JJ Link to comment Share on other sites More sharing options...
ComancheChic Posted April 15, 2012 Share Posted April 15, 2012 I have noticed full gauges in some MJ photos here. I would love to lose the idiot lights and install real gauges in my '90 2.5 w/ 4 spd. So find some from an MJ, yeah? I guess '90 or earlier? Mahalo for any info. Link to comment Share on other sites More sharing options...
