firemansteve6921 Posted March 26, 2012 Share Posted March 26, 2012 i am doing the infamous ba10 to ax15 swap. i have searched the threads and i cannot find the answer I'm looking for. are any of the parts associated with the clutch the same? flywheel--- clutch disc--- master cylinder--- bearings or bushings--- my truck is a 1989 4.0 2wd with the ba10 currently installed. before i buy a clutch kit or any parts i want to be sure I'm not wasting money bacause the clutch on my ba10 only has a couple thousand miles on it. if i can use any of the parts it would def help. Link to comment Share on other sites More sharing options...
Geonovast Posted March 27, 2012 Share Posted March 27, 2012 AFAIK, the only difference will be the internal slave cylinder. Link to comment Share on other sites More sharing options...
landlubber Posted March 28, 2012 Share Posted March 28, 2012 I used the same flywheel, I media blasted it. I used a new clutch kit, looking for what year I used, i'll update the post if I find it. I used the same master cylinder, but I used AN fittings and a line sold from advanced adapters: http://www.summitracing.com/parts/ADD-716130-60/ the bearing depends upon the year of the AX15 iirc Link to comment Share on other sites More sharing options...
MancheKid86 Posted March 28, 2012 Share Posted March 28, 2012 91+ ax-15 requires new pilot bushing Part number pb77 Or pb77hd (heavy duty) Have fun with the bearing, Took me 5 days with recomended ways of removing it. Even rented the proper tool, Ended up using a hammer and center punch. Took 15 mins and was about 6 pieces afterwards but it was way better than spending almost a week trying to get it out. Link to comment Share on other sites More sharing options...
firemansteve6921 Posted March 30, 2012 Author Share Posted March 30, 2012 thank you for the info. Link to comment Share on other sites More sharing options...
