What attaches to the fuel return in the tank?
In your image you see the remains of a tapered rubber grommet that secures that line
into the tray area of the tank. There's a locating sheet metal flange into which the
grommet is positioned. I don't think they're individually available, so JY is probably your
source. I think you may live just fine without it, since the assembly is pretty secure with
the main locking ring and gasket, but I would replace it to be certain. Looks like it's been
gone for a while now.
I must not have inspected the pump assembly very close. Does fuel actually flow through this rubber piece?
I searched though some pictures of my 92's pump assembly and it too has this plug. I haven't seen the assembly for a couple of years because it is all boxed up in storage.
