cmichaelvincent Posted March 5, 2012 Posted March 5, 2012 I was hearing a loud screeching noise every time I depressed my clutch pedal. Thinking it was my TOB, I replaced it and threw it back together only to find that it was still a screechy mess. So I decided to replace my pilot bearing, which was jammed so tightly in my crankshaft that I had to resort to using a dremel to grind the thing out. Alas, no respite from the banshee screech. So after tearing apart my drivetrain and putting it back together twice in one weekend, I realized the noise coming from me disengaging the clutch was caused by the engine side of the flywheel grinding up against the dust cover. I apologize for the terrible picture quality, but the scoring goes almost halfway around the plate and the flywheel had carved a crevice almost 2 millimeters deep in some spots. I tried bending the plate, which didn't make any meaningful difference. I "solved" the problem by slapping a couple of thick washers as spacers on the bolts at the bottom of the bellhousing, but I'm worried this may be a symptom of a larger problem. Does anyone have any advice to offer? I think my motor mounts may have failed and threw my alignment out of whack.
Exgrayxj Posted March 5, 2012 Posted March 5, 2012 Probably an unwanted opinion, but this could be a sign of a badly worn thrust bearing in the engine. :roll:
Blue XJ Posted March 6, 2012 Posted March 6, 2012 :soap box: Probably an unwanted opinion, but this could be a sign of a badly worn thrust bearing in the engine. :roll: That was my first thought too.
airspeed Posted March 6, 2012 Posted March 6, 2012 Could you grab the front of the crankshaft / lower pulley and see if it moves in and out longitudinal?
cmichaelvincent Posted March 18, 2012 Author Posted March 18, 2012 Sorry for the slow reply. The crankshaft is secure and does not move at all, axially. I don't believe the thrust bearing is to blame. I'm thinking the motor and transmission mounts are trash. I'm not going to bother replacing the pukey mount, but I will replace the MM's. I'll post an update next week. Edit: Thanks for the help, all. No opinions are unwanted here!
