I'm getting ready to open up the back side of a 242, and would like
to learn from someone who has been there and knows how to check
the chain for stretch. How much is too much? Conversely, would
the recommendation be to just preemptively replace it regardless?
I have no idea how many miles this unit has, I only know it shifts well.
Thanks for input.
even minimal stretch will cause issues. last time I purchased one, it was $90 bucks shipped brand new. put the new one in just to save yourself the headache long term.
Well, that was my leaning too, but is there any rule of thumb such
as mid span deflection to even judge stretch? I only want to go in
there once, but if a new chain deflects as much as the original one
did, seems there might not have been stretch. I don't have a good
feel for how tough (or not tough) these chains are. Comments?
What type of chain is it? I'm assuming Morse HY-VO but what is the width and pin type? Round pin chains are the toughest and noisest. Gold bar shaped (9600) are ok but 8600 chains suck.
I had a 231 with a chain so badly stretched it was skipping teeth and wearing a groove where it was laying on the bottom of the case. New chain was so tight I had trouble lining the shafts up perfectly to slip into the bearings.
In a 242 it may matter more.
I would put the shifter into part time 4wd (either high or low). Grab the rear output in one hand and the front output in the other ad twist them to feel for any slop between them. Should be hardly any.
