Abyx Posted February 16, 2012 Share Posted February 16, 2012 I did a search on this, I couldn't find anything..just looking for some pointers here. The P/O did a complete hackjob repair on the exhaust on my truck, to top it off, he had new pipes bent up and everything..except they're all the wrong sizes so they're crushed together with exhaust clamps, it's a complete mess, and I'm not looking to replace it...however I had to fix it, as the cat rotted off the muffler. I fixed that part. Now the problem I'm having, is the exhaust manifold studs are completely phuk-ed. They're stripped out and rotten, my question is how can I go about replacing them? Do I have to pull the manifold and drill them out? Can I just use an air-chisel and beat them out with the manifold in the vehicle? Can I use a hammer and punch? They're seized in there pretty good, I don't wanna risk cracking the manifold...so what would be my best option? I was hoping to have this done and the truck on the road either tomorrow or Saturday; but if I have to pull the manifold it's gonna wait. :( Link to comment Share on other sites More sharing options...
Dan.Keppel Posted February 16, 2012 Share Posted February 16, 2012 well depends how bad the studs are but if you can get a nut on them you can double nut them and back them out( you run one nut on all the way to the base and then another up to that one and tighten the two nuts together and then you should be able to back the studd out using the first nut) sounds weird but it works. or if you have a studd tool, which I'm guerssing you don't... Link to comment Share on other sites More sharing options...
jimoshel Posted February 16, 2012 Share Posted February 16, 2012 Had something like that a couple weeks ago. '87 MJ, 4.0L. Soaked with penetrating oil for a week before tried removing. Double nuts trick and stud removal tool. No work. Tried heating with torch. Nothing. Finally had the studs wore down till they were flush with the manifold. Removed manifold. Drilled out center of studs. Tried EZ Out. Ground hole out in one. Snapped EZ Out off in the other. Threw manifold into scrap and replaced with another one. Link to comment Share on other sites More sharing options...
Dan.Keppel Posted February 17, 2012 Share Posted February 17, 2012 lol i have never had that much trouble :wrench: :cheers: Link to comment Share on other sites More sharing options...
Abyx Posted February 17, 2012 Author Share Posted February 17, 2012 That's a pretty neat trick, I'll have to remember that..unfortunately, if I could get a nut on enough to actually thread it tight, I'd have no problem! I can't thread a nut back on, the threads are bad, haha. I might try re-tapping the threads for the fun of it, but I can't imagine it will work. I do have another manifold, but I'd raaather not have to swap them out since that's a bit of a job...especially considering it's a job I'm not looking to do at the moment. Link to comment Share on other sites More sharing options...
flint54 Posted February 17, 2012 Share Posted February 17, 2012 I was going to replace mine because the threads had wornj some. Ordered replacements, and they're knurled just like lug nut studs. Had the manifold off and observed that the heads are actually spot welded to the flange in two places. I cut this weld back as best I could with a dremel, and then placed the flange over a socket to provide support. I wailed on those miserable ba#$%@ds for a long time with my small sledge and they would not budge. I decided that mine will last a while longer as is. I hope you have better success, and suggest you just grind the heads off flush and then drill them out. I suggest you not beat on them unless the manifold is removed. Link to comment Share on other sites More sharing options...
jimoshel Posted February 17, 2012 Share Posted February 17, 2012 Another method I've used when all else didn't. Screw a nut onto the stud. Weld it. Wait for stud to cool. Now heat manifold while trying to remove stud. Link to comment Share on other sites More sharing options...
