Blinker problem
Is it exclusively the front, exclusively the back or both?
If it's both on one side, I'd check the turn signal switch...if you can get another one, just unplug it at the bottom of the steering column and plug the new one in and give her a whirl.
Other things to consider is the flasher relay, and the bulbs. If you testlight the connections on the end(ground the cable, stick the tip into the light socket with the signal activated to see if you're getting power), will give you a better idea of where to start from.
Flasher relays are about 8$
Turn signal switch about 25$(have to disassemble the column to properly replace this, it's really not too bad)
A test light is about 3$.
Have at 'er!
thanks guys...I tried the flasher relay first and now the left goes really fast and the right goes a lot faster than it did but not as fast as the left....lol...oh well now it blinks !...when it finally dies i'll have to change that switch...its only got 49,000 miles on it. Grandma bought it new, Dad bought it from her, I bought it from Mom
