M1A1TankerTom Posted February 6, 2012 Share Posted February 6, 2012 well after wheeling last weekend I did this to my comanche Image Not Found so after a trip to pick and pull I was able to upgrade the front end to a newer 97+ cherokee front end. I also removed the AC condenser and installed a B&M tranny cooler. With the condenser out of the way of the radiator I should run a little cooler in the temp department, I also routed the tranny lines to the tranny cooler only and bypassed the radiator so I'm hoping that helps keep the radiator temps lower as well. Anyways...here's some pics of the newer front end. I love how it looks :) Link to comment Share on other sites More sharing options...
sinkrun Posted February 6, 2012 Share Posted February 6, 2012 Looks good what did you use to paint your truck I like it. Link to comment Share on other sites More sharing options...
M1A1TankerTom Posted February 6, 2012 Author Share Posted February 6, 2012 its just camo rattle can OD green Link to comment Share on other sites More sharing options...
freakjeep93 Posted February 7, 2012 Share Posted February 7, 2012 howd ya bust the first header? Link to comment Share on other sites More sharing options...
M1A1TankerTom Posted February 7, 2012 Author Share Posted February 7, 2012 got wedged between two trees, had to back out. Caught the corner of the headers and ripped it off. Link to comment Share on other sites More sharing options...
dakal Posted February 7, 2012 Share Posted February 7, 2012 i like the look Link to comment Share on other sites More sharing options...
xjrev10 Posted February 9, 2012 Share Posted February 9, 2012 Ha. Looks familiar! Mine was a front impact at about 5mph. Link to comment Share on other sites More sharing options...
M1A1TankerTom Posted February 13, 2012 Author Share Posted February 13, 2012 hmmm....well today was the first time I actually went to drive the comanche since I did the front end swap and my head lights won't come on. I checked them both in high and low beams and they don't work at all but all the running lights and blinker lights come on. I checked all the wiring and everything is plugged in. I am gonna get all new fuses/relays tomorrow...if that doesnt work then I have no idea :( Link to comment Share on other sites More sharing options...
M1A1TankerTom Posted February 15, 2012 Author Share Posted February 15, 2012 guess it helps when you ground the headlights...problem solved :) Link to comment Share on other sites More sharing options...
imstuck Posted February 16, 2012 Share Posted February 16, 2012 Haha! After my conversion I did the same thing! No ground! Link to comment Share on other sites More sharing options...
