sunpro coolant temperature gauge
If you go the HO water outlet route be sure to check how far the probe goes into the housing. When I installed a mechanical guage on my truck I used the HO water outlet and used the smaller fitting on the guage and a pipe bushing to space the probe out enough to not bottom out in the housing. I pulled an HO water outlet from the Pull-a-part for about $5.00. I can post a picture tomarrow if you want.
