SandMountainJeep Posted January 28, 2012 Posted January 28, 2012 What is the easiest way to level the front end of a 4x4 Comanche? What does it need 1 1/2 to 2 inches? Thanks! 8)
Paul Bruchal Posted January 28, 2012 Posted January 28, 2012 http://motionoffroad.com/catalog/index. ... ath=13_219
SandMountainJeep Posted January 28, 2012 Author Posted January 28, 2012 Thanks, that a great site! What do you think the .75 or 1.75 spacers?
Paul Bruchal Posted January 28, 2012 Posted January 28, 2012 ID go with the 1.75". I don't know why, I like the front end just a little higher than the rear. Plus if you add a winch to your Jeep, it won't sag the front down as much with the extra weight.
SandMountainJeep Posted January 29, 2012 Author Posted January 29, 2012 Sounds like a winner to me. Thanks for all your help!
mvusse Posted January 29, 2012 Posted January 29, 2012 I had 1.75" in the front of the Pg and it sat as nearly level as I could tell.
Midnightrunxj Posted January 31, 2012 Posted January 31, 2012 Go to the pick and pull and get your self some front coils from a V8 zj Perfect to level your truck out and a better spring rate. Should be around $20
