Rymanrph Posted January 26, 2012 Share Posted January 26, 2012 I have new problem with my head lights. One of them only partially lights. It's just really dim. I have the auto pal housings with eautoworks harness. Any ideas? Link to comment Share on other sites More sharing options...
Motion Offroad Posted January 26, 2012 Share Posted January 26, 2012 Switch the bulbs side to side and see if it does the same thing with the other bulb in that housing/harness. If not than you have a bad bulb, if so you have bad wiring/connection. Also be sure to never touch the bulb itself with your bare fingers. The oil in your fingers can ruin the bulb. Link to comment Share on other sites More sharing options...
Jeep Driver Posted January 26, 2012 Share Posted January 26, 2012 Make sure all three prongs are in the socket. Mine did the same and one prong went to the outside of the socket when I plugged it in. Seems the H4 prongs on the autopals are a little off...........gotta kinda wiggle in on and adjust as you plug in. Was it supper supper dim? Link to comment Share on other sites More sharing options...
Rymanrph Posted January 26, 2012 Author Share Posted January 26, 2012 I just happened to notice it one night recently. I know it hasn't always been that way. I just recently installed a new fog light harness, so it's possible that the plug may have wiggled loose while I was installing. I'll check the plug first and then swap the bulbs. Link to comment Share on other sites More sharing options...
vaquaro Posted January 26, 2012 Share Posted January 26, 2012 I have the same harness , double check your grounds ( try running an extra ground loop ) as the self tapping screws to the body are not always reliable . :thumbsup: Link to comment Share on other sites More sharing options...
Rymanrph Posted January 27, 2012 Author Share Posted January 27, 2012 I have the same harness , double check your grounds ( try running an extra ground loop ) as the self tapping screws to the body are not always reliable . :thumbsup: You got it. It was a bad ground. Link to comment Share on other sites More sharing options...
